- 25 Oct 2007
I'm currently planning a new build using the evga680i A1 board.
The plan is to overclock the cpu fsb whilst maintaining a 1:1 ratio with the Ram.
By overclocking the fsb from 266 to 285 this would result in a speed of 1140MHZ as (285 * 4 = 1140)
My reason for doing this is that Corsair do a PC2 9136 dual channel kit which works out at 1140MHZ hence matching my over clock.
My question is, "Do I need to change any other settings or indeed the ratio in order to acheive the matched speeds or will the motherboard see that by overclocking the FSB to 285 the speeds are matched already?
I don't want the mobo to automaticly increase the speed of the ram aswell as this would thow the ratio out. If I do need to set a manual ratio can someone help me work it out as I'd like to try and get it right first time.
Sorry if this is a bit noob but I've never overclocked Ram before.
Any help is greatly appreciated.
Paul
Paul
