Hi,
I'm going to be buying all the stuff for my new system soon which i'll be building. This is my first build so was needing to know, what additional suff will I need other than all the pc components?
Will I need..
Thermal compound?
A CPU cooler (for c2d E8500 retail)?
additional fans?
additional cables?
the spec is..
.Intel Core 2 Duo E8500 LGA775 'Wolfdale' 3.16GHz (1333FSB) - Retail
.Asus ATI Radeon HD 4850 1024MB GDDR3 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail
.Gigabyte GA-EP43-DS3 Intel P43 (Socket 775) PCI-Express DDR2
.Kingston HyperX 4GB (2x2GB) DDR2 PC2-8500C6 1066MHz Dual Channel Kit
.Samsung SpinPoint F1 500GB SATA-II 16MB Cache - OEM
Many thanks!
Pete
Will I need..
Thermal compound?
additional fans?
additional cables?
the spec is..
Many thanks!
Pete
be sure to get one that has the right connectors for the GFX card and motherboard.
