Math Problem
30 Aug 2005
The M of K
ok been trying to do this puzzle all morning and cant seem to see it!
each diagonal is 8cm and u need to find the total area of the square
[/IMG]
*S any ideas?
Ohhh its a been a long time, erm.
You do:
(8^2)/2 = Answer. Answer x Answer = area in units.
Edit: whooo thats wrong.
You do:
i think that's right... using one of the triangles, two of the sides on that triangle are 4cm, using pythagoras we know that the third side of that triangle is the square root of 4^2 + 4^2, which is 'root32', but then considering it's a square the answer would be (root32)^2 which equals 32
Right sequence, wrong termanology. 4^2 +4^2 = 32, not root 32.
Burnsy
8^2 = a^2 + b^2, where a=b as it's a square.
64 = 2a^2
32 = a^2.. which is the area of the square if you think about it.
It has got an area of 32.
Just use Pythagoras to find the length of one side and square it.
Edit: I'm taking that when you say each diagonal is 8cm you mean from corner of square to corner of square.
You don't even need pythagoras.
Imagine they are four triangles. You could rearrange those four triangles to get two 4x4 squares :)
tbh, its quite simple and I'm guessing you did this in classes before being set the homework.
notes = win
Yup its my main pal Pythagoras and his thereom.
His thereom states:
The two shorter sides squared and added together make the longest side squared in a right angled triangle.
His thereom states:
It was more along the lines of
"The square of the hypotenuse is equal to the sum of the square of the other two sides"
