- 29 Jun 2004
Right. Tomarrow i've got a Mathematics Mechanics 1 exam so I thought it would be a wise idea to go over the things I am weak on before the exam to reinforce my knowledge. So, the topic is Dynamics of a particle moving in a straight line
That question may sound like quite a lot to take it but it is quite easy. All I need to do is resolve forces.
Now, the thing is, in question a) i'm always going wrong in a step and I don't really know why. I've compared my work to the answer in the book and i've found out where the error in my working occurs. Here is what the book gives (i'll highlight where I go wrong)
Now I understand everything else fine. But one question, how the hell did they get from T - 10g sin θ = 10a to T - 6g = 10a
Thanks
Mechanics 1 for Edexcel Book said:Two particles P and Q, of mass 10kg and 15kg respectively, are connected by a light, inextensible string which passes over a light smooth pulley. Particle P rests on a smooth plane inclined at θ° to the horizontal, where sin θ° = 3/5. Particle Q hangs vertically on the edge of the plane, 2 m above a horizontal plane. Find:
a) The acceleration of the system
b) The tension in the string
c) The total distance that P travels up the plae, given that the string breaks after Q has travelled up 1 m.
Mechanics 1 for Edexcel Book said:Particle P:
Parallel to plane:
F = ma
T - 10g sin θ = 10a
T - 6g = 10a - (1)
Particle Q:
Vertical motion:
F = ma
15g - T = 15a - (2)
9g = 25a
a = (9*9.8)/25 = 3.528 ms^-2
Thanks
