Maths Help - Easy Question - Need Clarification Please
4 May 2003
Guys,
Can someone please check that my workings below are correct, i'm fairly certain they are but something keeps nagging at me telling me that I am wrong. I would ask someone else but there is nobody home :(
The volume of a cylinder can be obtained using the formula V=LC^2/4pi
So: Volume = L * C squared divided by the product of 4 times pi.
The values I have for L and C are: L = 3.50m and C = 75cm
What is the approximate volume in meters cubed?
I got the approximate answer as 16m^3 and the exact answer as 15.66m^3 (2 d.p) Is this correct?
All help greatly appreciated.
Thanks
JonC said:
If you convert into cm first, you have to divide your answer by 100 for each dimension to convert it into m^3.
For example if you have a cube that is 1m x 1m x 1m, you have a cube that is 100cm x 100cm x 100cm, so in order to convert a volume from cm--> m, you have to divide by 100 x 100 x 100.
It sounds like you have divided by 100 x 100 (once for each measurement), but you need to divide by 100 again as the C measurement is squared ( eg (m x100)^2 = m^2 x 100^2).
You are correct, I can see where I went wrong.
Thanks to everyone for their input.
