Maths Notation (Sets)
7 Jan 2003
Gold Coast, Australia
Just trying to get my head round some maths notation some of it is ok but some im stuggling with.
Is {3} a sub set of {3}?
Does {3} = {{3}}?
Does 0 belong to the empty set?
Does 0 belong to the empty set inside a set?
Im also struggling with this double sum question, as im trying to teach myself this subject.
Does {3} = {{3}}?
Yes - but not a proper subset
No
What? No
What? No
Whats the actual question for that sum?
neocon said:
WHATS THE POINT OF KNOWING THIS?
If you cant easily work it out, quit.
:rolleyes:
Just got to evaluate the double sum.
All you need to know is that 1+2+....+n = 0.5n(n+1)
Then you can get rid of the sums. Seems a very strange question though?!
demon8991 said:
Yer i know ive read loads of examples about it but none are like that.
So the answer is just 0.5(n+1)?
No. If you look at the inner sum, you have (1+i) + (2 + i) + ... + (i + i). Split this up as 1 + 2 + ... + i, and i + i + ... + i (each sum has i terms). Use Lagz comment to work out 1 + 2 + ... + i and your own common sense for the other one. Then once you've worked out what the inner sum comes to (it will be a function of i), use that to work out what the outer sum is.
Hint: You will probably find it helpful to know that 1 + 4 + 9 + 16 + ... + n^2 = n(n+1)(2n+1)/6
demon8991 said:
Therefore does the inner sum equal i^2 + i + 1?
No. How did you work that out?
Whatever answer you get, it makes sense to check it for small values of i. Your answer doesn't work when i = 1.
demon8991 said:
Oh god im completly confused, i really need to be able to do this and its driving me nuts that i cant (im one of those people).
You want to evaluate the two sums completely separately. If you do the sum over j first, remember that i isn't being summed over at all, so what you have is:
(i+1) + (i+2) + (i+3) + ... + (i+i)
so you're adding i together i times, and then you're adding all the numbers from 1 to i. That should give you an expression for the sum in brackets, and then you need to sum that over i as well. To do that you'll need to know the expression for the sum from i=1 to n of i^2... which you can either work out or google.
Edit: Hah, I realised that I just repeated DaveF's post.
To clarify one of your earlier questions, the reason that {3} is not the same as {{3}} is because sets are only equal when every element is the same. The only element of the first set is 3, while the only element of the second set is {3}. Are these equal? Clearly not, because one is a number and the other is a set.
To learn it and understand it.
Although I see where you're coming from in a way. Knowledge is useless without application, but if he wants to learn it, or needs to learn it, then that's application enough.
