Maths question, need help!
11 May 2006
A little stuck with the following trigonometry question, would appreciate some help!
Solve cot(2x)-tan(78)=1/2*sec(x)*sec(78) for 0<=x<=360 degrees.
I've gotten it to cos(2x+78)=sin(x) but not sure what to do now or if this is completely wrong.
Would really appreciate some help!
sin(x)=cos(90-x) basic trig id
implies 2x-78=90-x from your equation.
then solve for x
this all assumes your rearrangement is correct....i cant be botherdd to check that
then solve for x
I did this and got one solution, but how do you get the rest of them? Plotting the two graphs shows four solutions within the required range.
Then your simplification must be wrong as that only leads to a single solution as per Impy77s answer
ps3ud0 :cool:
No. Because Sin and Cos are periodic, there are an infinite number of solutions to sin(y) = cos(x), our OP needs to work out all the ones in the range 0-360
This.
Doesn't help that the question is in degrees. For this sort of stuff, radians are so much easier to work with.
