MATRIX 7970 PLATINUM!
14 Apr 2013
I HAVE A ASUS MATRIX 7970 PLATINUM I BROUGHT IT LAST WEEK AND THE SOUND WONT COME THROUGH IT :s
I GOT IT ON MY 32 INCH PLASMA WHICH COME FROM DVI TO HDMI,
MY OLD CARD USED GIVE SOUND, IVE PUT THIS IN AND UPLOADED ALL THE DRIVERS AND IT DOESNT GIVE SOUND OUT,
I GO ONTO SETTING AND IT SAYS AMD NOT PLUGGED IN :s
CAN ANY 1 HELP ME PELASE
hi welcome to the forums
DVI(digital VIDEO interface) does not support audio, to get audio to your TV you will need to run a cable from your motherboard to your TV
umm maybe it does taken from another thread
"Audio will be sent over the DVI link with the HDMI adapter. While it's not an official part of the DVI spec, this has been a common feature on video cards for a very long time. You just need to make sure that the SPDIF components of the Catalyst driver package is installed."
Have you been into catalyst control center to look for any audio options?
