Matrox graphics cards
27 Aug 2004
Hi guys, ive come across a kuput fan on an unkown model Matrox card.
My quest is to obviously replace this fan, but my side quest is to make it quiet as posible. Trouble is, ive never used matrox kit before never mind had to fix it! It looks rather similar to a Gforce 5XXX series card? Any ideas guys?
How wide apart are the screw holes? If you're lucky you could bodge a NB heatsink and fan onto there... might not be the quietest though.
Thanks for the reply buddy,
Heatsink is 50mm x 50mm. The locating plugs are 15mm in (right = 15mm down from the top, left = 15 up from the bottom). Plug to plug is 59mm.
Hope this makes sense?
