Mattresses - Where from?
7 Nov 2002
Snorbans, UK
Hey,
I'm in the process of buying a new bed, and i'm wondering about matresses.
Where's best to get them from? I like a firm matress (hurts my back otherwise) - Is it best to go into shops and try them out?
cheers :)
Have a look at foam ones. They have no springs so are totally silent, mines really stiff too, but I'm sure you can get stiffer/not as stiff ones ;).
Plus, as a bonus they come rolled up so fit in the back of your car. You simplly undo them and they expand :) Make sure you do this in your room, else you're a fool.
where did you get yours from?
A local shop (can't think of the name) not a big chain. It was a couple of hundred, i'll see if I can find the name.
Might be a bit out of budget :p although i shouldn't skimp on that, gotta sleep on it!
Right can't find any names on the mattress, without removing all the sheets, so it may be tommorow :D.
Is your bed a single or double? Single would be cheaper I'd imagine, and they should last for years :).
i'd definitely try some out in the shop, as if you sleep 8 hours a day thats a third of your time in bed, so you want it to be comfortable.
I've got a single at the moment, buying a double :)
I bought a double Ikea bed and matress for uni, VERY impressed with it. I needed the strongest bed I could find ;) within my budget and got a metal one from there. Very comfy and very rigid. Smidget over £200 for both, was an offer this 14 months ago.
I've been looking at matresses recently and the best advice I can give you is go and humiliate yourself in the showroom and lay on some. Just pokeing and proding a matress won't do you need to actually take your jacket off and lay on it for 5 minutes.
You back should be supported lightly by the mattress and your shoulders and butt should sink into it just a little. A good test of this is to lay on your back and to slide your hand (flat) under the small of your back, if your hand slides in to easily the mattress is probably too hard as your back isn't being supported, if your hand won't go in at all then the mattress is probably too soft and you are sinking too far in.
Its important that YOU try this and don't rely in the manufacturers rating of the mattress because a firm mattress will feel softer to me than to a very light person who won't make much impression on it.
There are three or four main types of mattress
Continiously sprung - these have an open bed of springs and padding over the top. Because the springs are woven together then the mattress isn't always responsive enough to individual parts of your body and if you sleep with a partner your weight may effect the contour of their side of the bed. Price range ~£50-500 (kingsize)
Pocket sprung - Imagine these like one of those toys with thousands of individual pins which will make an imprint of your hand. Pocket springs operate independantly and hence can respond to the contours of your body without effecting one another. These tend to be more expensive but the top beds are made in this way. The more springs the more finely the mattress can respond to your shape. You MUST MUST MUST test these if you are considering one, just pressing your hand on it will give a false impression of how soft they are, your have to lay on it, try on your back and your side for a minimum of 5 minutes ~£500-£5000 for a kingsive
Tempur - These are special foam mattresses made from a 'memory' material, they 'squidge' to your bodyshape supporting you everywhere, I found them very strange, coming from a continiously sprung mattress they feel almost too responsive filling every gap under you, almost like I would expect a waterbed to feel. When I got on one I felt like I was in that scene in Trainspotting where he sinks into the carpet! These are expensive ~£1000+ for a kingsize
Foam - These come in a variety of softness and react more like a continiously sprung mattress in my experience, they tend to deform around the indent you make as well as accomodate you. If the one you chose is too firm it will be like laying on concrete, too soft and you'll be sunk into it which won't do your back any good.
If you have a bad back don't be taken in by anything labeled back care or orthopedic, its a watch word for firm and they tend to be continiously sprung, we have one at the moment and I'm quite happy with it but firm doesn't mean it will be best for YOUR back.
We're pretty settled on a pocket sprung zip and lock superking set by Hammond, which is two mattresses which zip together to make one. This means we can have one in firm and one in extra firm to accomodate the weight difference between my wife and I and eliminate roll together (minimal with a pocket sprung anyway) :)
Test them
Spend the most you can afford
Your spend ~1/3 of your life in bed and a good sleep effect the rest of the 2/3rds
Go to an independant dealer who won't give you harsh looks for actually laying on the beds, places like Harveys and major retailer are just rubbish it this and hate to have the place made untidy, an independant will encourage you to try and explain the different technologies.
Hope that helps, enjoy your new bed :)
MB
Matblack said:
All of the above is excellent advice. I've just spent £700 on a pocket sprung king size and it's absolute bliss. Got it from Sleepmasters, who were absolutely superb. Two of the sales guys were happy to swap mattresses onto the base we wanted to make sure it was the right one for use, we spent a good 40 mins testing them out.
dragonflyy said:
Ebay have plenty of foam mattresses. Would never ever go back to a sprung mattress ever!
I'm very suprised that anyone would buy an object they will trust their back health and 1/3rd of their day to without trying it out first. Particularly from ebay where a £10 hunk of rubbish foam could be marked up as an decent matress.
I only spend a few minutes a day on average in my car, yet I test drove loads before making a decision. If you don't try before you buy you might get lucky but then again you might not have got the best option available do yourself a favor and test drive some matresses first.
MB
A good Pocket Sprung one ( 2000 ish springs ) , we bought one about 4 years ago ( around £700 ) and it has been wonderful , still as good as new too
As Matblack says they initially feel softer than they are , if you sit on the edge of ours it will almost tip you on the floor but it provides wonderful support when lay down
