MATX air cooled gaming rig
1 Nov 2008
New project time, it's a MATX air cooled gaming rig, open chassis with carrying handle, really easy maintenance, hopefully I've put enough thought into it all holding together well. :D
Just getting the pieces made before I start bending/curving, assembling, doing a little each day on it.
Cut, drilled, tapped & added m3 brass inserts to the back IO expansion piece, made from 10mm acrylic.
Mounted to the back panel.
Mobo panel added.
Saving the curve cuts for when I have the curved pieces done to increase chance of lining up correctly.
Curved & bent the PSU cover, front panel is just resting in place.
I'll try to post progress every time I reply to keep it a productive log, posting in a few places so that could be regular progress. :D
This is going to be an excellent build. DIY cases are always smashing :D
Where did you learn these DIY skills to build your own case?
Thanks :) skills & tools have built up from nothing in 2008 & ongoing, been making roughly 1 new case per year, sometimes more than 1, learnt a lot along the way, still make mistakes though. :D
Load of drilling & tapping for mounting the 33mm acrylic support blocks.
And added 10mm acrylic psu cover supports.
Fantastic, original idea. I admire people so much who have the skill to carry out a project like this.
This is awesome!
Thanks Brad. :)
To do.
HDD slot mount.
Back panel curve cut.
Rest of the fan assembly parts.
Front USB 3 & power button (40mm marble).
Maybe add a couple more mount points for extra solidness.
Case feet, 2x 10mm square bars on both sides.
Surface & edge finishing.
I bought silverstone cable extensions to make quick easy work of cabling, plenty of cable stash room under the psu cover & the side casing.
USB cables & fans ordered.
Still undecided about adding decorative layers.
So I'll leave updates until I've done all of the above.
Stunning, love it
Thanks Collin. :)
Ah, made a pretty big blooper but can ya see it, is it an obvious error, is to me but is it to you, the viewer?. :D
For me it's an error I can just about live with, disappointed about it but can live with it since it would mean I'd need to remake at least 2 significant pieces, maybe more.
