Matx best choice motherboard
Permabanned
29 Feb 2004
Hi guys
Basicly here's my plan's.. Just brought a Silverstone SG-01 Evolution (thanks Ka0ticMind) and plan to put my current system in there.... while my main case (wavemaster) i sell to make room for another case and custom watercooling setup im planning! my system spec are...
I would like your opinion on the following motherbaord for my new case, baring in mind i have an opteron 148 that does 2.8Ghz without real voltage change.. and would like to atleast achieve 250fsb if possible also has to be PCI-E and obviously s939 so my choices are...
Asus A8V-VM
Biostar GeForce6100-M9
FoxConn CK804K8MA-KS
FoxConn NF4XK8MC-RS
Asrock 939NF4G-SATA2
Asrock 939S56-M
GigaByte K8NMF-9
GigaByte K8N51GMF-9
thats the list of motherbaords from my local computer shop all priced around the same mark!
I had/have each of these:
Gigabyte K8N51GMF-9
The chipset fan failed on the foxconn and I couldnt get a replacent to fit it, my first gigabyte randmoly stopped posting (yet upon returing it to a compatior it mysteriously started woking again - apparently)
The Biostar 6100 is the best from that list for overclocking. It can do over 300 with ease. However it does lack some of the features of the other few with it having the slightly inferior 410 chip and 6100 graphics.
The DFI Infinity RS482 is even better, but pricey.
