mATX Build - Anything Missing?
5 Mar 2003
Nottingham
Need to upgrade my current C2D build - keeping the SSD, GFX, monitor etc. but all the other components need to change. Just want to make sure I've not missed anything / incompatibility issues.
Code:
Case:		BitFenix Prodigy M MATX Cube Case - Midnight Black	£ 75
Motherboard:	Asus GRYPHON Z87					£120
CPU:		Intel Core i5-4670K 3.40GHz (Haswell) 			£170
PSU:		Seasonic G series 550w					£ 70
Memory:		Patriot Viper "Black Mamba" 8GB (2x4GB)	1866MHz 	£ 70
Cooler:		Corsair Hydro H100i 					£100
Total:									£605
If I were to put one of the latest top end GFX cards, I take it the PSU would cope?
Cheers!
PSU should be fine for a single card system.
Prodigy has better cable management than the Phenom, i'm currently torn between the two myself, edging toward the Phenom on looks alone though(but each to his own). I'll also be going ITX instead, i prefer the layout of the ITX versions personally(it will support a single dual slot card and the PSU is mounted in a better position).
Didn't see them... But adds another £50 to the build price and rad goes from 2x 120 to 1x140...
Thanks for the PSU info!
