mATX Build
15 Nov 2008
Reading
I recently had a thread for a build for a ITX case, but I've now gone and bought a TJ08, so looking for some advice on a build for this.
I have a rough idea of what to go in and how I'm going to go about doing it, but thought I'd check in here first. ;)
I plan on getting a basic dual core for the mo until Ivy is out, then I can see if its worth going for it or getting a 2500k.
I already have the case, an Intel 520 180GB SSD and 8GB of HyperX.
Budget for the rest is ~ £500 including a Celeron G530 for the moment.
Build wise, what I'm thinking at the moment is something along the lines of this:
YOUR BASKET
1 x Sapphire HD 7850 2048MB GDDR5 PCI-Express Graphics Card £194.99
1 x Asus Z77 Maximus V Gene Intel Z77 (Socket 1155) DDR3 Motherboard £156.98
1 x XFX 650W XXX Edition Modular '80 Plus Bronze' Power Supply £72.98
1 x Intel Celeron G530 2.40GHz Socket LGA 1155 Processor - Retail £29.99
1 x FOXCONN NetDVD External DVD-Writer - Black £19.99
Total : £486.94 (includes shipping : £10.00).
I'm not too sure whether the Gigabyte G1 Sniper M3 would be a better bet seeing that its cheaper.
Any advice would be great. :D
Ok, the TFIII looks pretty nice. Going to go for the Maximus V as it has an 8 pin CPU power connector instead of 4 - might help it overclock better ;)
Anyone else? Looking to order this tonight.
That looks great, gonna be one hell of a build.
You gonna be OCing? Don't forget an aftermarket cooler.
Id go for the TFIII if you can, i have a GTX 460 HAWK (TFII) and it is a lot cooler than the old card i had, under load and idle.
You womt get much of an OC from a G530, 2.5Ghz if your lucky.
You won't be doing much heavy gaming on a £29.99 dual core.
If you can afford to wait another 3 weeks then I wouldn't bother trying to get it running until ivybridge is released.
Plus, you can by the components over this time when you seen them on offer to save yourself a few quid ;)
I've been waiting for over two months, and having to use a computer with a single core athlon, 512mb ram, ide hdd at the moment is a bit of a pain ;)
Got it all setup yesterday and after a few issues with the ram, its all setup and running fine now :D
BTW, if you don't have an SSD, you're missing out.
