MATX case but for 24 drives
24 drives wow what are you using it for to power nasa i dont think there is any cases that can support 24 hard drives
Dream on, your best chance it a custom build.
The market for small cases that take 24 drives is far too niche.
On page says:
Motherboard: HPTX / EATX / ATX / Micro-ATX
It would hold the other drives in the 5.25". You can buy hot swap caddies which could easily add the remaining drives you need.
Yeah, good luck with that! 24 3.5" drives on their own stacked on top of each other is 1ft of space alone, that's 75% the internal size of most big mATX cases. that's not even allowing for any space between the drives.
If you want to fit 24 drives, it's either a big tower case or a rackmount 4u case that you'll need.
