Can anyone recommend an MATX case that's around the same size as an NZXT Manta that can support 2 radiators?
The Manta is big for an ITX case. The MATX ENTHOO EVOLV is roughly the same size as the Manta, as are a few other MATX cases I found.That would be pretty hard to do seeing as the NZXT Manta is a mini-itx case....
I think I've settled on the Enthoo Evolv.
Rajiintek Styx - 1 240 and 1 120 rad
Enthoo Evolv Matx - 1 360 and 1 240
Fractal Arc mini - either 2 240's or a 360 and 240 (not sure)
Evolv matx isn't the best for cooling. The panels restrict airflow too much. Using one myself and GPU temps are 10-15 degrees cooler with the panels off.
Aindees crystal cube lite will do the job
I had the arc mini and ran 240 + 360, both radiators were mayhems havoc which are 60mm thick with no issues.
I had to sacrifice all the drive bays but wasnt much of an issue
I'm thinking it won't be any worse than the manta I have currently. What do you think? The Manta has quite restrictive mesh vents on the edges of the panels.
It's a nice looking case but it's too big for what I need it for.
Is it one without 5.25" bays?
