mATX Case
17 Nov 2011
I'm looking for a mATX case for my HTPC which will hold these components, case dimensions must be below 18 cm height and 45 cm width so I can place it on the second shelf of the TV stand, budget is £30-45,
CPU: AMD Phenom II X2 545 3.0GHz
Motherboard: Foxconn A7VMX-K mATX
RAM: 4GB ASint Technology PC2-6400 DDR2 (400MHz) 2x2GB
GPU: ATI Radeon HD 5500 Series 512MB
HDD: Western Digital 7200RPM 500GB SATAII
PSU: Channel Well Technology 405W Standard ATX
I would think that budget is quite tight, the Silverstone GD04/05 would be a perfect fit for the components and dimensions, but is closer to £70-80
