mAtx Cases for lower temperature
2 Dec 2020
Hi,
My temperatures are pretty shocking so I need a new case. The two I am split between are Meshify C mini and the Lianli Lancool 205M. The Lancool is nearly half the price, but does not look as good.
Any thoughts on either one or suggests on other mAtx cases? Must be similarish in size, I dont need a super small case, my current is 400mm tall and 360mm deep.
Thanks!
I've got a meshify c mini and with 2x140mm intakes I have no issues cooling a 3700x and a 5700xt while playing any game.
With a good fan curve it's also silent under no load.
If you have any more questions then I can help.
Thanks!
Doesnt it come with 2 120mm stock fans? Have you added 2 140mm to it?
