mATX CPU cooler
Don
5 Oct 2005
Liverpool
Hey People,
I was wondering if you can give me the top five Intel CPU coolers that will nicely fix in a mATX case... I'm looking at an 15 quad and I'm stick on what CPU cooler I should be looking at...
Also if you want to suggest a case I'm open to suggestions :)
Stelly
The Sugos have 70-something mm to play with, so you're looking at stock cooler, something low profile like the CNPS-8000, or the passive SS NT-06 Evolution.
For something like a Mini-P180 you can get whatever you like in there, i'd recommend a Corsair H5O.
The Lian-Li V350 will take full 120.2 watercooling but if you want air i'd have the Scythe Mini-Ninja.
Tute your a ****ing gem mate :)
Stelly
If your running a sugo be careful, i'm running a q6600 with the silverstone NT06, i'm on my second psu now, and it's showing signs of the fan failing (same as the first) I just dont think they can cope with the heat. My psu fan now is already making grinding (bearings) under intense load, wont be long till it's gone and i'll be looking for another.
grrrrr..... ok I might reconsider on the case size....
Any ideas on a silent CPU cooler?? I'm not overclocking
Stelly
