REVISION 1
x2 4200
2gb ddr2
ga-ma78gm-ds3h
gpu HD5450 - temporary for tests only
chieftec 600W CFT600-14CS
chassis is from phillips freevents RIG, but only front and part of top is diffrent than other OEM foxconn chassiss
REVISION 2
asrock m3a780gmh/128
sempron 140
2x2geil ddr3
As you can see, I mount hdd's backward - 15 minutes of cut metal and drill sides and done.
Now I can switch hdd even faster than previous (front is mounted to metal construction by 6 plastic clamps - very easy to remove)
REVISION 3
Athlon II 250 + IFX14 passive (for fun)
HD5850 fits perfect - 5mm too hdds
REVISION 4
I changed mobo to DFI 790GX-M2RS
cooler scythe zipang (140mm)
2x hd5850 (for fun only, with running pc turn over a little oven lol)
HDDs:
2x1TB
2x1,5TB
250gb (sys)
and cable managment
As you can see I need to extend front panel (pwr on/reset itp and usb) cables
x2 4200
2gb ddr2
ga-ma78gm-ds3h
![1a.jpg](http://omniserver.pl/4ddd5/kompy/HTPC1/1a.jpg)
![2a.jpg](http://omniserver.pl/4ddd5/kompy/HTPC1/2a.jpg)
![3a.jpg](http://omniserver.pl/4ddd5/kompy/HTPC1/3a.jpg)
REVISION 2
sempron 140
2x2geil ddr3
![stage2.jpg](http://omniserver.pl/duniek/kompy/HTPC1/stage2.jpg)
REVISION 3
![stage3-1.jpg](http://omniserver.pl/4ddd5/kompy/HTPC1/stage3-1.jpg)
![stage3-2.jpg](http://omniserver.pl/4ddd5/kompy/HTPC1/stage3-2.jpg)
![stage3-3.jpg](http://omniserver.pl/4ddd5/kompy/HTPC1/stage3-3.jpg)
REVISION 4
HDDs:
2x1TB
2x1,5TB
250gb (sys)
![stage4.jpg](http://omniserver.pl/duniek/kompy/HTPC1/stage4.jpg)
and cable managment
![st41.jpg](http://omniserver.pl/4ddd5/kompy/HTPC1/st41.jpg)
![st42.jpg](http://omniserver.pl/4ddd5/kompy/HTPC1/st42.jpg)
![st43.jpg](http://omniserver.pl/4ddd5/kompy/HTPC1/st43.jpg)
![st44.jpg](http://omniserver.pl/4ddd5/kompy/HTPC1/st44.jpg)
