- 20 Feb 2013
- Carnoustie
Do you think if we could get enough signatures on a petiton, we could present to BitFenix an idea of how many people actually want this product for awesome designed mATX goodness?
I think the size of the prodigy was good considering what you could get in and the cooling options it has. You can wedge some high end hardware in and keep it running at decent temps.
The handles are the main reason the prodigy appears so big. You can fit an awful lot into them though. As can be seen here:
Project Unobtainable Build Log - X79 & Crossfire in a white Bitfenix Prodigy - all custom watercooled
TL;DR version with piccies
I really don't get the draw with the case. It is NOT Small Form Factor, if I was mod i'd move it all over to Case Central.
If you like the looks then fine, but to try and put it in the same league as the cases above is just wrong.
+1, theres matx cases already smaller than the mitx prodigy
Really? Care to post some links?
Silverstone Sugo SG01, SG02, SG03, SG04, SG09, SG10, FT03, TJ08, TJ08E.
Lian-Li V350, V351, V352, V353, V354, V355, A01, A03, A04.
NZXT Vulcan.
fractal node 304 can take big air coolers and 310mm graphics cards too
But the question is how many of those can take long GPU's and a massive air cooler, like the prodigy can?
FT03, TJ08, TJ08-E, Vulcan.
Anymore?
With respect, you're totally missing the point. If you want a massive cooler then go for a massive case. Plus the majority of those can be watercooled with little to no modding.
