Hi, so I want to down-size to micro atx and I was unsure about a couple of things. I'm currently running a 4800+ am2, on an Asus M2N32-SLi-DLX, 4gb geil ram. Taking the opportunity to swap over to core2.
So heres the spec.
Lian-Li V350B Aluminium Mini-Tower - Black
instead of my thermaltake shark
Asus P5E-VM HDMI Intel G35 Micro-ATX (Socket 775) PCI-Express DDR2 Motherboard
Intel Core 2 Quad Pro Q6600 2.40GHz Guaranteed to run at 3.00GHZ (1333FSB) - Retail
to replace my am2 components
Seagate Barracuda 7200.11 1TB SATA-II 32MB Cache - Retail (ST310005N1D1AS-RK)
to use as my storage drive, swapping out my current 250gb C drive and using my 500gb drive as my boot drive instead
using my current 4gb of GeIL PC2-6400C4 800MHz Ultra Low Latency
my hiper psu
and my 8800GTS (until I have the funds to upgrade)
My main questions are, does this spec look ok?
Whats that case like for space and airflow, without watercooling is it likely to get stuffy in there?
Can anyone recommend a cpu cooler thats quiet and will fit in there?
Will my hiper ATX psu fit alright, just a double check. It does say on the spec it fits ATX psu's.
Don't think I missed anything. Might have, its early after all
So heres the spec.
my hiper psu
