- 29 Oct 2002
Hi folks,
I'm planning an upgrade from my aging Coolermaster Silencio 352 in anticipation of going custom water at some point, but I'm struggling to find a case that ticks all my boxes. I have a list of requirements below, I'm happy to sacrifice one of two to get the right case, so here goes:
- Matx board size max. Atx or e-atx would be wasteful
- Vertical GPU (required)
- 240 rad capable
- cable management and access top bottom and usual edge of board, rubber grommets preferred for entry points.
- PSU shroud (required)
- tempered glass
- 5.25" bay
- intake filters (front access preferred but not mandatory)
RGB i'm not too bothered about. If it's there, i'd use it but it's not critical (can always add my own later, if I fancy it...)
After some research, the closest I've found is the NZXT H400i, tho this is missing the 5.25" bay (can live with that) but it lacks the vertical GPU option. I've also looked that the R5 but this is a bit spartan and is lacking a PSU shroud. Is there anything out there that fulfills my needs or am I going to have to consider the R6 atx sized boxes to get it all??
As always, thanks in advance for any guidance
DB
- 240 rad capable
- tempered glass
- 5.25" bay
DB
