Does anyone know of a Matx case with a vertical gpu mount, I am not after a case with a horizontal mobo I would want the mobo to be vertical too please.
Thanks
Am sure i have seen a review vid of a vertical gpu bracket that you can convert most cases. It takes up most if not all of your pcie slots in the case. It was a bt a big name brand i.e fractal or cablemod
https://bit-tech.net/reviews/tech/cases/metallicgear-neo-g-mini-review/1/
review has a link to the place you can buy it from.
its the neo-g that you're after, for £69.90
npi would like to thank you for posting this link up even though it was not helping me directly.
rgb fans are overratedone RGB fan and you cant yet buy there fans.
better to get good fans and use an led strip for rgb if you're desperate lol
