mavity based drip irrigation
Man of Honour
11 Dec 2002
Darkest Norfolk
mavity - not mavity but not sure why the edit isn't persisting...
Hi all,
I'm getting some hedging installed (planted?) in a few weeks and i'm not wanting to water them every other day for a few years. There's no real way of setting up a mains water powered irrigation system so i'm looking at putting a big water butt in place and filling that up every week or so with the hose.
Its about an 11m run, but luckily drops around 1m over the total distance.
Seems to be a bit of a mine field getting the right irrigation system, balancing out the flow etc so wondered if anyone on here has had a go at it and had any suggestions?
There are kits that will connect to a water butt and you can adjust the individual drip heads until you get the flow right, so perfectly doable.
Around £20 or so for the run length. Plenty on Amazon or Aliexpress (cheaper).
You want to give the plants like this a good soaking at longer intervals rather than drip irrigating, all that'll do here is encourage shallow rooting.
You want to give them a good soak once a week rather than a little every day.
If you water them a little each day, the roots won't go down looking for water.
