Max amount of memory for XP?
22 Jan 2004
Hi guys,
Coes anyone know what the max amount of memory is viable for XP home edition(32bit)?
I currently have 2gb running in dual channel and was thinking of buying another stick or 2.
Cheers Ferret
Thanks Ataro,
I have 2gb at the mo, running in dual channel so if i get another 1gb that will stop it running in dual channel.
Do you know if this is a major drop in performance?
Thanks
Ferret
Thanks Ataro,
Thanks
Ferret
Nope, no major drop.
memory right now is so cheap you can get a 2GB pc6400 stick for less than £18 and 2 stick of 1GB for around that price so even if it only see 3GB it will really speed up multitasking a lot.
32bit OS will read 4GB, subtracting your amount of graphical memory from that. So, if you have a 512mb graphics card, you'll get 3.5gigs in Windows.
64bit is a few petabytes IIRC, something silly that no one is going to use for atleast a few years.
As long as you add another matched pair of memory (2 x 512mb or 2 x 1GB, etc) you won't lose dual channel. I'd suggest adding another pair of EXACTLY what you have now for best performance and stability.
i thought it gets to see 3.5gb and then u minus your video memory from that?
i dont have 4gb so not 100% sure
