Max E5200 voltage?
1 Aug 2007
Hi all
How high can I have my E5200 voltage?
I'm currently at 1.392v and stable at 3.7GHz (322x11.5).
My idle temps are 34c, 37c and max temps 65c.
If can go higher then 4GHz might be possible.
Thanks
Its recomended to stay at 1.4v or under, for 24/7 use, that being said i used to give my old E5200 cpu 1.45v 24/7 as its such a cheap cpu to replace, i was'nt to bothered.
Main thing is that your cooling is upto it, im sure others may agree, or some will say to def stay under 1.4, but best to wait to see what the majority think.
Ok I thought that was the case. Shame really fancied 4Ghz stable. I might see if I can get it stable at 1.4v with a lower multi and higher FSB.
Thanks
