Max Led header Question
30 Dec 2018
Hi,
Just noticed the maximum LEds per header for my motherboard is 80.
I was going to go for the triple phanteks d30s which have 30 LEDs each, daisy chained would make 90 thus im assuming 10 of the LEDs will not work?
If that is the case, then what are the options?
Would a seperate RGB controller work and if so which would you recommend?
Appreciate the help, should have noticed before i bought the board :cry:
Dritzz
I would, and do, use an ARGB hub for my lighting ( build link in signature).
Make sure it's a powered one, no risk of overload ING the mobo header then.
Mine is a Deep cool, which I can recommend, but there are many to choose from.
