Max memory voltages for ASUS P5B
9 Mar 2006
York
Hi, does anyone know if you can get anything higher than 2.1v on this board as its a bit on the lame side most of the 6400 and 8500 Ram that runs that without even overclocking. The bios will only let me raise it to 2.1v and its stopping me pushingmy Ram to higher speeds.
xHave you tried the latest BIOS? Failing that, there's gotta be a Voltmod (if yer brave)!
I'm thinking of getting a P5B.... How is it? Apart from the Vram issue, is it good?
Good board apart from ram volts, had a e6300 at 3.2ghz stable. That was using some Kingston value ram 5300 at over 900mhz should have stuck with that ha ha.
