Max Operating Temp For my RAM
7 Aug 2010
Newcastle upon Tyne
Hi,
Im just curoius as to wheteher on not my RAM temp is high, under full CPU load with no swapfile using BOINC, RAM temp is sitting @ 52c Using a Silverstone SST-FP52 front panel display with temp probes
I have 4x2G http://www.pqi.com.tw/product2.asp?TT=6&cate1=164&PROID=358#1
there is no mention of Max temp on the spec am I getting close to it ?
Thanks in advance
shaun
if your worried about ram temps just stick a fan on them, but to be honest i dont think anyone ever checks the temp of there ram...
i wouldnt worry about it.
is the ram overclocked?.. overvolted?
