- 12 May 2010
- West Bromwich
Not posted for a while lads but got a question...
I've got two 580 phantoms in SLI. If I disable SLI, then the top card will overclock to 940Mhz, stable. However, when I enable SLI, the max I can get is 870.
Is this because the bottom card is a worse clocker?
Also, for any of you lads running sli, do you put the same voltage through both cards? At the moment I have 'synchronize settings for similar gpu's' clicked in afterburner. Is this best practice?
Thanks
Thanks
