max safe overclock volts for ram?
20 Sep 2011
I have just upgraded to
F4-3200C14D-32GVK
as I have an ITX motherboard im limited to 2 slots only hence 2 x 16gb kit
anyway I just wanted some clarification of the max volts I can run daily on this ram?
im not sure if there will be more stress on the ram as its 16gb per stick
the ram will be watercooled which probably doesn't mean much but I do it for aesthetics
also the pads will be replaced with TG minus 8 pads
also what is a good program/programs to check the overclock is stable?
:cool:
HCI Memtest, plenty of info on the net how to set it up / run it. Around 1.45v, I've run mine at 1.5v for some time now with no issue.
