- 11 Jan 2011
Hi, im trying a bit of overclocking with my i7 2600K Sandy bridge setup.
spec is
Asus P8P67 Pro
i7 2600K
GeIL 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz VALUE PLUS Dual Channel
Noctua NH-D14
My setting are
BCLK - 100
Multiplier - 46
Vcore 1.250
Internal PLL voltage - Disabled
Memory frequency 1600MHz
Ram Timings are, 9-9-9-28
Load-line calibration - Auto
VRM Frequency - Auto
VRM spread spectrum - Disabled
Phase Control - Standard
Duty control - T.Probe
Cpu Current capability 100%
CPU Voltage - 1.250
Dram voltage 1.600
VCCSA Voltage - Auto
VCCIO Voltage - Auto
CPU PLL Voltage - Auto
PCH Voltage - Auto
DRAM DATA REF Voltage on CHA - Auto
DRAM CTRL REF Voltage on CHA - Auto
DRAM DATA REF Voltage on CHB - Auto
DRAM CTRL REF Voltage on CHB - Auto
CPU Speed spectrum - Auto
using Intel Burn test V2.54
Max temp core #0 -- 57c
Max temp core #1 -- 65c
Max temp core #2 -- 66c
Max temp core #3 -- 63c
everything is stable but i want to know what the limits of the vcore and max temp is?
Thanks
Matthew
spec is
Asus P8P67 Pro
i7 2600K
Noctua NH-D14
My setting are
BCLK - 100
Multiplier - 46
Vcore 1.250
CPU Voltage - 1.250
Dram voltage 1.600
PCH Voltage - Auto
Thanks
Matthew
