Maxbook not starting up
17 Oct 2006
Bristol
I have a 2006 Macbook which i was using last night when it restarted, for which I assume was heat issues, when I to turn it back on it doesn't load. It makes the Apple noise and then stays on the blue screen.
What can i try?
Thank-you
Try booting from your install disk, open disk utility and then select your drive and click 'Repair permissions' and once that is finished 'Repair disk'.
I tried doing that but it does the same thing.
Before I tried your suggestion I left it on its blue screen for a while and it started flashing a picture of a folder with a question mark in it. This suggests to me it's a dead hard drive. I hope not :(
Why doesn't the OSX install disc do anything though?
