Maximise application to secondary screen?
22 Dec 2008
England
I'm drawing a blank on this one. I've got two screens running, as far as I can tell with no problems at all, from an 8800gt. I can drag things between them fine, but if I double click on vlc in an attempt to maximise it on the secondary screen, it fills the primary one instead.
This is not really what I want it it do, so I'd appreciate a hint on how to solve this.
it's either a problem with your graphics drivers, your video Codecs or VLC itself.
try installing CCCP and using the included MPC:HC to play your media.
MPC:HC is much better than VLC anyway...
Ah, cheers. It appears to be a failing on vlcs part, windows media player can cope without any issues.
Thanks for the suggestion (and the solution that dropped out of it) but I think I'll stick with vlc, even if it is misbehaving.
