Maximum amount of memory?
4 Jul 2004
aberdeen
Hi
What is the maximum amount of memory?
At the moment i have a 64bit cpu, running a 32bit version of vista. What is the max i can get?
Depends on your mobo, the board can only support a certain amount of GB's! Check ya mobo manual, should tell you in there.
The maximum theoretical memory address space in a 64-bit system is 2^64 addresses, equivalent to 17,179,869,184 gibibytes or 16 exbibytes of RAM.
In reality it depends on your motherboard/memory controller. Newer consumer mobos seem to lie in the 16 GiB range.
EDIT: The Abit AV8 maxes out at 4 GiB RAM.
The board will run 4gb. However, regardless of your CPU, the OS is 32bit. In a nutshell, with 4gb of memory installed, your OS will allow the system to assign approximately 2.6gb - 3.2gb for use by applications.
To "fully" utilize 4gb+ of memory, you need a CPU, MOBO (chipset) and OS that will allow you to use it all. Any weak link in the chain will cause you to be able to use less than 4gb.
