maximum safe voltage for e6600
4 Dec 2002
ilkeston derbys
hi
as above i have it running at v1.3250 on a 3.2 o/clock and ita idling/browsing at 42c. thought id check with you guys/gals.
cheers
On air temps will probably start to get out of control around 1.45ish....on water 1.5-1.55V 24/7 is fine in my book.
Keep load temps under about 65c and you are fine
sounds ok ill prob pump it up to 1.4 and keep an eye on load temps . load temps are mid 50s at the moment
cheers
I have pumped 1.55 through my e6420 which is probably identical to an e6600 really, without problems default voltage is 1.35.
