Maximus V Gene CSM Problem
29 Sep 2004
Wilt of the Shire
I've started getting the following error message and can't figure out what's causing it:
The current BIOS settings do not fully support the boot device. Go to Advanced > Boot > CSM Parameters and adjust the CSM Parameters to enable the boot device
I've got a 2600k OC'd to 4.4 GHz but it also does it when it's running at stock. I have made no changes hardware-wise to my PC and I've been running W10 Pro for about 7 months now.
The only thing that gets me back into windows is if I reset the CMOS. It all works fine for a while and then I get this error again forcing me to reset the CMOS. I've changed the battery, it's set to AHCI and when I reset all the drives show up in BIOS. Done memtest and memory is ok.
Anyone had this before?
