Maximus VI Formula here in a few days and its a beauty!!
20 Jul 2009
The bleak North East arm pit of Britain
:o
Gorgeous board, gorgeous spec! :cool:
Asus Z87 MAXIMUS VI FORMULA Intel Z87 (Socket 1150) DDR3 ATX Motherboard @ £259.99 inc VAT
"The Republic of Gamers consists only the best of the best. We offer the best hardware engineering, the fastest performance, the most innovating ideas, and we welcome the best gamers to join in.
In the Republic of Gamers, mercy rules are only for the weak, and bragging rights means everything. We believe in making statements and we excel in competitions. If your character matches our trait, then join the elite club, make your presence felt, in the Republic of Gamers."
The Intel® Z87 Express Chipset is a single-chipset design to support socket 1150 Intel® 4th generation Core™ i7/i5/i3/Pentium®/Celeron® processors. It provides improved performance by utilizing serial point-to-point links, allowing increased bandwidth and stability. Additionally, Z87 chipset features both the USB 3.0 & SATA6Gb technology for faster data retrieval speed. Moreover, Intel® Z87 Express Chipset can also enable iGPU function, letting users enjoy the latest Intel® integrated graphic performance.
CPU
- Intel® Socket 1150 for 4th Generation Core™ i7/Core™ i5/Core™ i3/Pentium®/Celeron® Processors
- Supports Intel® 22 nm CPU
- Supports Intel® Turbo Boost Technology 2.0
Chipset
- Intel® Z87
Memory
- 4 x DIMM, Max. 32GB, DDR3 3100(O.C)/3000(O.C.)/2933(O.C.)/2800(O.C.)/2666(O.C.)/2600(O.C.)/2500(O.C.)/2400(O.C.)/2200(O.C.)/2133(O.C.)/2000(O.C.)/1866(O.C.)/1800(O.C.)/1600/1333 MHz Non-ECC, - Un-buffered Memory
- Dual Channel Memory Architecture
- Supports Intel® Extreme Memory Profile (XMP)
Graphic
- Integrated Graphics Processor
- Multi-VGA output support : HDMI/DisplayPort ports
- Supports HDMI with max. resolution 4096 x 2160 @ 24 Hz / 2560 x 1600 @ 60 Hz
- Supports DisplayPort with max. resolution 4096 x 2160 @ 24 Hz / 3840 x 2160 @ 60 Hz
- Supports Intel® InTru™ 3D, Quick Sync Video, Clear Video HD Technology, Insider™
Multi-GPU Support
- Supports NVIDIA® Quad-GPU SLI™ Technology
- Supports AMD 3-Way CrossFireX™ Technology
Expansion Slots
- 3 x PCIe 3.0/2.0 x16 (x16 or dual x8 or x8/x4/x4) *1
- 1 x mini-PCIe 2.0 x1 *2
- 3 x PCIe 2.0 x1
Storage
Intel® Z87 chipset : *3
- 6 x SATA 6Gb/s port(s), red
- Support Raid 0, 1, 5, 10
- Supports Intel® Smart Response Technology, Intel® Rapid Start Technology, Intel® Smart Connect - Technology *4
- 1 x M.2 (NGFF) Socket 2 on mPCIe Combo II expansion card(s), black
- Support M.2 (NGFF) Type 2242 SSD card (22mm x 42mm), Support PCI express 2.0 x1 and SATA 6Gb/s standards
ASMedia® ASM1061 controller : *5
- 4 x SATA 6Gb/s port(s), red
LAN
- Intel® I217V, 1 x Gigabit LAN Controller(s)
Wireless
- 802.11a/b/g/n/ac + Bluetooth V4.0
Audio
- ROG SupremeFX Formula 8-Channel High Definition Audio CODEC
- Supports : Jack-detection, Multi-streaming
- SupremeFX Shielding Technology
- Cirrus Logic® CS4398 DAC: 120 dB SNR, -107 dB THD+N (Max. 192 kHz/ 24 -bit)
- TI 6120A2 high fidelity headphone amplifier
- WIMA® film capacitors
- ELNA® premium audio capacitors
- High-fidelity audio OP AMP(s)
- Differential circuit design
Audio Feature :
- Blu-ray audio layer Content Protection
- Sonic Radar
- DTS Connect
- Optical S/PDIF out port(s) at back panel
USB Ports
Intel® Z87 chipset : *7
- 4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
Intel® Z87 chipset : *8
- 8 x USB 2.0 port(s) (4 at back panel, black, 4 at mid-board)
ASMedia® USB 3.0 controller :
- 4 x USB 3.0 port(s) (4 at back panel, blue)
Back I/O Ports
- 1 x DisplayPort
- 1 x HDMI
- 1 x LAN (RJ45) port(s)
- 6 x USB 3.0 (blue)
- 4 x USB 2.0
- 1 x Optical S/PDIF out
- 6 x Audio jack(s)
- 1 x Clear CMOS button(s)
- 1 x ROG Connect On/ Off switch(es)
Internal I/O
- 1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s)
- 2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
- 1 x TPM connector(s)
- 10 x SATA 6Gb/s connector(s)
- 1 x CPU Fan connector(s)
- 1 x CPU OPT Fan connector(s)
- 3 x Chassis Fan connector(s)
- 3 x Optional Fan connector(s)
- 1 x S/PDIF out header(s)
- 1 x 24-pin EATX Power connector(s)
- 1 x 8-pin ATX 12V Power connector(s)
- 1 x 4-pin ATX 12V Power connector(s)
- 1 x Front panel audio connector(s) (AAFP)
- 1 x System panel(s)
- 1 x DirectKey Button(s)
- 1 x DRCT header(s)
- 1 x MemOK! button(s)
- 10 x ProbeIt Measurement Points
- 3 x Thermal sensor connector(s)
- 1 x Power-on button(s)
- 1 x Reset button(s)
- 1 x FastBoot switch(es)
- 1 x ROG extension (ROG_EXT) header(s)
- 1 x mPCIe Combo II connector(s)
Only £259.99 inc VAT.
ORDER NOW
**** me ****ing sideways so much want right now that is an awesome looking board, i thought the old sabretooths and my mpower were good looking but ging dong this ones a looker.
looks fantastic, need a board to pair up with a 4770k sitting on my desk. Was considering the asus hero but this looks so much better.
