Maxwell BIOS Tweaker Help
  • Thread starter Thread starter Raiden85
  • Start date Start date
20 Aug 2020
South Wales
I have 2x MSI GTX 980 Ti Gaming 6G, one card will boost to 1354mhz out of the box and the other 1329mhz.
Not much I know, but the faster card will only run at the slower cards speed, so what want to do it permanently add an extra 25, 30mhz to the BIOS on one card so that both will boost to the same clocks of 1354mhz instead of doing it via software like AfterBurner.
Just need to know which option in the tool to add the extra couple of mhz.
Should I change the TDP base clock, 3D base clock or the boost clock so that the card will boost the extra 30mhz or is it another option.
Thanks
Thanks for that, I have increased the clock of the slower card by 30mhz, it now boosts to the same speed of 1354mhz as the faster one. Very happy with that, glad I picked the right card in nvflash.
Flashed both cards earlier as well as I tweaked the fan speeds and at what temps the fans adjust to on both. Wanted to keep the fans running permanently at 15% when idle (660rpm) as I didn't like the high idle temps.
Can't hear them at all, and instead of idling in the in the high 30's (38c to 40c) they now idle at 28c to 29c in a 24c case temp.
