Just fixed an Accelero S1 onto my x1900xt, with terrible results. I was having a hard time getting the stock cooler off and during a battle with one of the screws I must've hit the surrounding area; I have no idea whether those tiny yellow squares on the board are transistors or capacitors or something else, but the yellow casing on one of them has partly chipped off. The metal inside doesn't seem to be damaged, but I don't know what is in there :S. I also forgot to get some thermal tape so have stuck the ramsinks on with the sticky stuff that the stock cooler came with for now.
Currently speaking to you in safe mode, but when I try and start-up normally I can only get past the loading screen before my monitor loses signal. I guess what I want to know is whether I can get this yellow thing replaced, or is it a lost cause? Also, for future reference if needs be, if direct contact between the ram heatsinks and the ram chips is essential, without sticky thermal stuff in between?
Cheers
Cheers
. Also, the thermal tape that comes with the sinks, as has been stated many times before, is pretty useless.
