Maybe it's me - blu ray players and 4k tv
23 Nov 2014
The Cronx
Hi all
I'm scratching my head, trying not to just buy a new HD Blu Ray player...
I have a Samsung 6 series 4k TV which works great, and my Roku, HTPC and Fire Box all work fine. However when I try my two admittedly old blu ray players the 1920x1080 signal is detected but the screen is blank. I understand this might be something to do with HDMI handshaking....so.....
I've updated to latest firmware on both players on a 1080 tv which works fine
I've tried every combo of cable and input on the tv
Anything else left to try?
Players are Phillips BDP5000 (ancient) and Samsung BD-F5500
Many thanks
I've used all 3 cables I use on that TV, including one I use for the HTPC which plays 4K video and desktop
eta - the bluray players output 1080p which is at least detected - the label that pops up when you select the relevent HDMI source says 1080p
Just because its Samsung I would stick with that BD player (just to make testing a little simpler) - wondering if you can reset to factory settings on the 1080p screen and then plug it into the Samsung TV?
I reckon there is something in the picture settings getting mucked up- I would also be tempted to use one of the non 4k HDMI inputs on your 6 series tv (like mine the 4k may be switchable between the inputs)
