** Mayhems Fine Silver Kill Coil - 99.999% Fine Silver **
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
The call for an ultra pure Kill Coil has been answered. Mayhems products all go under intensive testing and this Coil is no exception.
I asked for kill coils from Mayhems a while ago and their response was they they simply weren't happy with the quality of raw materials.
This has changed recently and an ultra pure coil is now in stock and ready to ship.
This is a perfect compliment to Mayhems Ultra Pure H20 Watercooling Fluid 1L
Mayhems Fine Silver Kill Coil @ £4.50 inc VAT
Mayhems Silver Coil is a Silver Coil made in the UK using the highest grade fine English Silver. Its is made with 99.999% fine silver and will not corrode or rust like some other coils out there on the market.
The coils ate 8cm long, 3cm wide and 0.03cm thick
Each coil is acid cleaned and then placed in a sealed bag and then placed in a sealed bottle.
We recommend you use one coil per ½ a Ltr of water. So two coils for 1 Ltr of water.
These could will fit any diameter of tubing.
Only £4.50 inc VAT.
ORDER NOW
hi guys,
basically if you have a watercooling loop and just use distilled water, adding a silver coil to your reservoir [or placing it in the tubing] will prevent the growth of bacteria as it acts like an inhibitor.
essentially, if you have a watercooling loop, and you dont use a coloured coolant with specialist biocides, one of these is essential for keeping it clean :)
Can you use this in conjunction with mayhems pastel range?
Also does it fit in the tubing or can you just dunk it in your resorvoir?
I have a EK DCP 2.2 combo.
The pastels range have the biocides already added and they state there is no need to add anything to them for your system.
"These could will fit any diameter of tubing." Is what is being pointed out there, small mistake.
Good to know that they didn't put out a product simply because they weren't happy with quality. Sign of a good product right there.
