I've got a minor growth issue in my loop, I haven't touched it for years. I only noticed as I finally (after over 3 years) decided it was time to delid my 8700k.
Got an extra 200mhz and 20c lower temps so was worth it.
I did empty the loop, flushed it a few times with distilled water and put some new Mayhems X1 in there but after that I noticed there's what looks like some minor growth in the cpu/gpu blocks (both copper).
Mayhems X1 says premixed so I don't think I needed to add anything to stop this? maybe I should have added a silver coil when I first put it together?
I really don't want to start taking blocks apart and cleaning them with a tooth brush, is there anything I can run through it that would do a decent job of cleaning it? Honestly it's not *that* bad so will just leave it if it requires pulling the whole thing apart, especially since the temps are really good.
Got an extra 200mhz and 20c lower temps so was worth it.I did empty the loop, flushed it a few times with distilled water and put some new Mayhems X1 in there but after that I noticed there's what looks like some minor growth in the cpu/gpu blocks (both copper).
