- 6 Jan 2013
- Rollergirl
I built the loop 6 weeks ago (see link in signature), ran it for 3 weeks and then had to leave it off for 3 weeks as I was at work. I've just got home and noticed a fair sized bubble in the motherboard mono block. I turned the pump speed up full to try and disperse the bubble and shift it into the res... And it seems like the XT1 has clogged or thickened because my water has went from clear to cloudy, very cloudy, especially in the res.
Is this normal after a loop has been dormant for a couple of weeks?
Will it clear?
Should I drain and get rid of this fluid ie is it now contaminated?
Will it clear?
