MB issues flashing orange Light
2 Oct 2007
Uttoxeter,Uk
Hello,
My MB is P55-GD80 MSI model MS-7581. (bought Jan 2010)
Pc Spec:
CPU: Intel Core i5 750 2.66GHz (Lynnfield) (Socket LGA1156)
MB: P55-GD80
RAM: Corsair XMS3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
Card: MSI HD 7850 Twin Frozr III OC 2048MB GDDR5 PCI-Express Graphics Cards
This morning, I went to turn it on. nothing no boot or fans power on, but this has happen b4 then sometime it will power on if I wait.
But this time I look at the MB light its flashing orange (Standby light) just above the battery. took it out but new one in and reset the cmos and nothing.
So I check the PSU Ocz 700W (bought round 2009) unplug everything but 3 Pin Fan power lead in to a 4 Pin Molex power connector.
I did Testing a Power Supply with The Paper Clip Test. It power up psu and fans so that working fine.
So question is, is the MB gone and need replacing or Im i missing anything
Regards
Nicholas
Aye buddy that looks fine as long as the motherboard fits your case, however looking at your old one it should not be a drama
