mb with 8 sata sockets
10 Apr 2004
Weston-Super-Mare
Hi, I'm looking for a motherboard with 8 SATA sockets so i can run 8 seperate harddrives, any cpu socket will do.
thanks in-advance.
Quick look shows the Gigabyte DS4 to have 8. Bet lots of others will have too.
I know its not the answer your looking for, but thinking our the box, you could use 2 SATA controllers with 4 ports each on ANY motherboard if its old.
Most Mobos nowadays have 8 I think.
Thanks for the replys,, its not in that pc, its going the other pc i have the DFI UT RDX200CF mb is having problems with one to two sata sockets so i'm looking to replace that.
