- 15 Jan 2010
- Scotland
Hello,
Looking for some advice and to see if anyone else has ran into this problem. Connected my new MacBook Pro 16" to an old LG 23MP65 IPS 1080P monitor via a USBC/HDMI cable (the cable is rated for 4K@60FPS).
When the display is running either as a mirror or extended, every 4-5 seconds there is a stuttering on the display, almost like it skips a frame, the best way to describe it is if you are making a circle with the cursor it sticks or jumps every few seconds.
I have bootcamp installed but the issues doesn't seem to exist when running Windows. Anyone else had a similar issue or suggest anything that could be changed in settings? I have stopped macOS from switching to the iGPU and forced it to use the 5400M but this hasn't made a difference.
Thanks!
Thanks!
