I have have a MBP 2020, was purchased in July last year and as of lately the machine holds zero charge. Your lucky if you get 2hrs out of it. The laptop is always plugged in as just the nature of the work I do its needs to be connected to power 90% of the time but obviously I do use it as a laptop away from a power source. So for a machine that isn't even a year ld I do not believe it should be this bad, it only has 120 odd cycles.
So what should I do, get in touch with Apple?
I have tried clearing the SMC and I was going to try the recalibrate technique but my understanding is that modern batteries should be able to be connected to the power source all the time without degrading battery performance?
