MBP dock
18 Oct 2002
Hi Guys
I am thinking of treating myself a new MBP and External monitor instead of a new iMac.
what are these dock people using? Is there so thing I can either dock or connect to then all external and monitor is connected right away know what I mean ?
HengeDock is very well thought of, just put your MBP in and then a couple cables coming out to go into your monitor. Can look really clean if you use a USB-C monitor
Monitor - USBC - Dock then just plug any peripherals into the monitor and have a single cable for everything.
Alternatively you can just get USB-C dongles that will give you HDMI, Ethernet, USBC, USBA and so forth. A bit more messy but a lot cheaper and you can also pack the dongle in your bag for when you go away.
